"Show Region Utility" an ELSE section
With ADDT I have the possibility with a single operation to view alternative text or another recordset when the conditional region not found a valid value.
Is available this function in your PHP Framework?
No the show region utility does not include an else function.
Instead you can simply apply it twice with the opposite condition. This would be equivalent to an else, but is more portable since it could be placed individually.
I will log this a feature request to include else functionality directly in the interface, but it should be easy to achieve the same result with framework builder by simply applying it twice.
