PowerCMS - Templates sequence
Thread began 8/10/2010 9:33 am by webwerkt | Last modified 8/16/2010 10:10 am by Dani Chankhour | 1334 views | 3 replies |
webwerkt
Can I influence the order of appearance of Templates? For example.
I created a Template and used it to create pages like;
• Home
• Contact
• Help
• Guestbook
In this case the list above will also be the order of appearing, meaning that “Home” Will be the page appearing as the first (index) page.
But Suppose, I would like the “Contact” page to appear as the first page, what sold I do?,
Is there anything that can be moved.
Dani Chankhour
The only way to change the ordering is through the database. If you look in the contents table, you will see that there is a 'ContentPageSetOrder' filed that is set for each of the sub template pages. you can set the contact page to be the first by setting that column to 1, but you will need to change the other sub pages along with any additional regions for that page to the correct 'ContentPageSetOrder' value as well.
webwerkt
Power CMS2 - Make it more practical
Jammer / Pity,
Maybe something for the future.
thanks 4 the reply
Dani Chankhour
Thanks. We will definitely consider this option in future releases.
