Multiple data insert with checkbox (variation)
I am trying to get the insert page to use all the data provided before my bolt pattern checkboxes, loop through the bolt patterns adding a new record to the database, if that checkbox was selected and use just that value for that record.
The idea is to be able to insert many records to the database with on click of the insert button. All the data for the records is constant but the bolt pattern. I need only one bolt pattern per record. for instance, if I had 10 different bolt patterns and selected 4, when I click the insert button I would get 4 different records in my database and the only thing different in the records is the bolt pattern.
I hope I explained this clear enough. Attached is my insert page I am working on. Any help would be much appreciated.
Thanks,
Bknvc
