Installation Wizard Step 1- Diagnostics -Having an Issue
Thread began 8/08/2010 6:50 pm by kelly.lucas.3335626 | Last modified 8/09/2010 1:39 pm by kelly.lucas.3335626 | 539 views | 4 replies |
kelly.lucas.3335626
The Problem: When I go to the Installation Wizard, I can't get past step 1- Server Diagnostics.
The Error is with File Permissions. I get this error: "Files and directories cannot be created. Verify the powerstore directory has write permissions on your server."
However, when I log into my client's cpanel, and go into File Manager and check the directory I uploaded the files to, the Permissions for "user" are set to read, write, and execute.
What do I need to do to get past this? I did upload the 2 fixes that were mentioned. (I did not upload the Fix for errors from changing the store name.) Am I looking at the wrong thing in cpanel? If so, redirect me as needed.
Basically, What do I need to do to fix this?
Thanks for your time.
Kelly
Your cpanel should show 3 different users, each of the three users should have read and write Permissions:
Owner: Read, Write, Execute
User: Read, Write
Everyone: Read, Write
kelly.lucas.3335626
cpanel
It shows User, Group, World
Should i set all 3 anyway??
Yes, all three need to have read an write access.
kelly.lucas.3335626
Did not work
I set all 3 to write and it did not work. I still get the same error. What else can I do?
