dataassist error step 1
Hi guys
Im using cs5 and dataassist2 on step1 of the dataassist wizard im getting this error
"Unidentified error has occurred!" any help will be very welcome.Thanks
regards karl
Hi guys
regards karl
Karl,
Are you on Mac or PC? Wondering if there may be some sort of cache issue. Also, have you tried to define another site and try that... perhaps there is an issue with the connection or a testing server variable may not be set correctly. I would double check to make sure all of your folders and paths are set correctly in your testing server set up within the Dreamweaver site definitions.
Best regards,
Brian
Im on pc, i will try what you have said. Thankyou for the reply, lets hope it works.
Regards Karl
Good luck Karl... if you run into any problems just post back and I will continue to help if needed.
Brian
Hi Brian
Just a quick update and a huge `thankyou` what you said has worked, dataassist2 is doing exactly what i ask of it. Once again many thanks
Regards Karl
