DataAssist date field is not updating correctly
Thread began 8/05/2010 8:31 am by sandy170299 | Last modified 8/05/2010 3:25 pm by Jason Byrnes | 1786 views | 6 replies |
sandy170299
I am using a MySQL database and the field type is set to DATE. Whenever I try to change the date, using DataAssist, it comes back to me as 0000-00-00. It's not updating correctly. The Update Option Data Type is being set to Date, within the DA wizard. I've never encountered this before and I'm not sure how to fix it...???
when posting date data into a mySQL date column, it must be in the yyyy-mm-dd hh:mm:ss format.
any other format such as mm/dd/yyyy will cause this problem
you can use the php date function to reformat your date before it is entered into the db, send a copy of your page, And I will give your code change that needs to be made.
sandy170299
Thanks, Jason. Here is the code. Another thing I'm using is a javascript date picker, which is formatting the date in another format. This is probably contributing, too?
<?php require_once('../Connections/jimmy.php'); ?>
<?php require_once("../WA_DataAssist/WA_AppBuilder_PHP.php"); ?>
<?php require_once("../WA_iRite/WARichEditorPHP.php"); ?>
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
$theValue = ($theValue != "") ? "'" . doubleval($theValue) . "'" : "NULL";
break;
case "date":
break;
case "defined":
break;
return $theValue;
$ParamID_WADAevents = "-1";
if (isset($_GET['ID'])) {
$ParamID_WADAevents = (get_magic_quotes_gpc()) ? $_GET['ID'] : addslashes($_GET['ID']);
mysql_select_db($database_jimmy, $jimmy);
$query_WADAevents = sprintf("SELECT ID, eventName, eventDate, eventInfo FROM events WHERE ID = %s", GetSQLValueString($ParamID_WADAevents, "int"));
$WADAevents = mysql_query($query_WADAevents, $jimmy) or die(mysql_error());
$row_WADAevents = mysql_fetch_assoc($WADAevents);
$totalRows_WADAevents = mysql_num_rows($WADAevents);?>
// WA Application Builder Update
if (isset($_POST["Update_x"])) // Trigger
$WA_connection = $jimmy;
$WA_table = "events";
$WA_redirectURL = "events_Results.php";
$WA_keepQueryString = false;
$WA_indexField = "ID";
$WA_fieldNamesStr = "eventName|eventDate|eventInfo";
$WA_fieldValuesStr = "".((isset($_POST["eventName"]))?$_POST["eventName"]:"") ."" . "|" . "".((isset($_POST["eventDate"]))?$_POST["eventDate"]:"") ."" . "|" . "".((isset($_POST["eventInfo"]))?$_POST["eventInfo"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,NULL|',none,''";
$WA_comparisonStr = "=|=|=";
$WA_where_fieldValuesStr = "".((isset($_POST["WADAUpdateRecordID"]))?$_POST["WADAUpdateRecordID"]:"") ."";
$WA_where_columnTypesStr = "none,none,NULL";
$WA_where_comparisonStr = "=";
$WA_where_fieldNames = explode("|", $WA_indexField);
$WA_where_fieldValues = explode("|", $WA_where_fieldValuesStr);
$WA_where_columns = explode("|", $WA_where_columnTypesStr);
$WA_where_comparisons = explode("|", $WA_where_comparisonStr);
$WA_connectionDB = $database_jimmy;
$updateParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WhereObj = WA_AB_generateWhereClause($WA_where_fieldNames, $WA_where_columns, $WA_where_fieldValues, $WA_where_comparisons );
$WA_Sql = "UPDATE `" . $WA_table . "` SET " . $updateParamsObj->WA_setValues . " WHERE " . $WhereObj->sqlWhereClause . "";
if ($WA_redirectURL != "") {
<?php include("adminHeader.php"); ?>
<link href="../WA_DataAssist/styles/Traditional_Granite Pine.css" rel="stylesheet" type="text/css" />
<link href="../WA_DataAssist/styles/Verdana.css" rel="stylesheet" type="text/css" />
<div class="WADAUpdateContainer">
<?php if ($totalRows_WADAevents > 0) { // Show if recordset not empty ?>
<form action="events_Update.php?ID=<?php echo(rawurlencode($row_WADAevents['ID'])); ?>" method="post" name="WADAUpdateForm" id="WADAUpdateForm">
<div class="WADAHeader">Update Record</div>
<div class="WADAHorizLine"><img src="../WA_DataAssist/images/_tx_.gif" alt="" height="1" width="1" border="0" /></div>
<table width="600" border="0" cellpadding="0" cellspacing="0" class="WADADataTable">
<tr>
<th valign="top" class="WADADataTableHeader">Event Name/Location:</th>
<td valign="top" class="WADADataTableCell"><input type="text" name="eventName" id="eventName" value="<?php echo(str_replace('"', '&quot;', $row_WADAevents['eventName'])); ?>" size="32" /></td>
</tr>
<tr>
<th valign="top" class="WADADataTableHeader">Event Date:</th>
<td valign="top" class="WADADataTableCell"><input type="text" name="eventDate" id="eventDate" value="<?php echo(str_replace('"', '&quot;', $row_WADAevents['eventDate'])); ?>" size="32" />
<input name="pickDate" type="button" id="pickDate" onclick="KW_doCalendar('eventDate',0)" value="Pick Date" /></td>
</tr>
<tr>
<th valign="top" class="WADADataTableHeader">Event Info:</th>
<td valign="top" class="WADADataTableCell"><?php
// WebAssist iRite: Rich Text Editor for Dreamweaver
$WARichTextEditor_1 = CreateRichTextEditor ("eventInfo", "../WA_iRite/", "100%", "350px", "Basic", "../custom/events_Update_eventInfo1.js", "".$row_WADAevents['eventInfo'] ."");
?></td>
</tr>
</table>
<div class="WADAButtonRow">
<table border="0" align="right" cellpadding="0" cellspacing="0" class="WADADataNavButtons">
<tr>
<td class="WADADataNavButtonCell" nowrap="nowrap"><input type="image" name="Update" id="Update" value="Update" alt="Update" src="../WA_DataAssist/images/Granite Pine/Traditional_update.gif" /></td>
<td class="WADADataNavButtonCell" nowrap="nowrap"><a href="events_Results.php" title="Cancel"><img border="0" name="Cancel" id="Cancel" alt="Cancel" src="../WA_DataAssist/images/Granite Pine/Traditional_cancel.gif" /></a></td>
</tr>
</table>
<input name="WADAUpdateRecordID" type="hidden" id="WADAUpdateRecordID" value="<?php echo(rawurlencode($row_WADAevents['ID'])); ?>" />
</div>
</form>
<?php } // Show if recordset not empty ?>
<?php if ($totalRows_WADAevents == 0) { // Show if recordset empty ?>
<div class="WADANoResults">
<div class="WADANoResultsMessage">No record found.</div>
</div>
<?php } // Show if recordset empty ?>
</div>
<?php include("adminFooter.php"); ?>
mysql_free_result($WADAevents);
sandy170299
Just out of curiousity, Jason, shouldn't this be a feature built in within DA, to fix the dates before inserting them into the database? Most people I know are not going to enter a date in a yyyy-mm-dd format. Just my thoughts... :)
change:
$WA_fieldValuesStr = "".((isset($_POST["eventName"]))?$_POST["eventName"]:"") ."" . "|" . "".((isset($_POST["eventDate"]))?date("Y-m-d h:m:i", strtotime($_POST["eventDate"])):"") ."" . "|" . "".((isset($_POST["eventInfo"]))?$_POST["eventInfo"]:"") ."";
it can be argued both ways, if you had a text field where you where storing the date, you would not want the date format to automatically reformat it on insert, the issue only really occurs when you have a date field.
sandy170299
Thank you - worked perfectly. Still would be nice if it would do it for you :)
glad to hear it is working
