Add to Cart works locally
Thread began 8/05/2010 7:53 am by Kamen Nikolov | Last modified 8/05/2010 2:17 pm by Jason Byrnes | 620 views | 3 replies |
Kamen Nikolov
Hello,
My result pages, detail pages and add t cart buttons work fine locally but when I transferred them to the server it is not adding the items to the cart and from result and detail pages the cart (eCart 5) is coming as an empty.
Any superstitions?
I have similar issue with the User Registration Solution Pack. It works fine when log in as admin locally but not on the server.
I will appreciate any help.
Thank you.
I suspect there is an issue with session management on the remote server.
See the following post for a sessionTest.php file that can be used to test the servers session management:
showpost.php?p=23826&postcount=2
if the session test fails, you will need to contact the host to have them fix the issue with session management.
Kamen Nikolov
Thank you. That was the problem.
Great, glad to hear it is working.
