Path to Connection folder generated incorrectly
Hello,
I am trying to use SecurityAssist and have had a problem with the generated code. I apply the extension (Dreamweaver CS4) to a form on a page that is in this sample location:
/MainSite/registration/registration_page.php.
SA php files are generated in the same folder (/MainSite/registration/). For example, userRegistration.php is generated here and the 1st line of this file is:
<?php virtual('Connections/connuser_registration.php'); ?>
The problem is that the Connection folder is at /MainSite/Connections/ so the path is wrong and I get errors when I try to run. (I don't know if it matters, but this Connections folder was originally created at this location when I installed and configured Universal Email. That extension had no problem finding the Connections folder.)
If I manually alter all of the generated code as follows, the extension runs so I can manually patch it up but it seems that it should not have generated this wrong path to begin with.
<?php virtual('../Connections/connuser_registration.php'); ?>
Can you tell me why the wrong path was generated?
Thanks.
