Special Registration issues
Thread began 8/04/2010 11:22 am by fdotmedia | Last modified 8/10/2010 2:13 pm by Jason Byrnes | 924 views | 7 replies |
fdotmedia
ok - I've finally gotten back to this irritating problem I've been having for months...
Here's how the easy log in feature should work...
1. The registration page checks the email for duplication - redirects to duplicate.php
2. password is there
3. orgcode exists in the database
Here's how it works!
Currently, We let EVERYONE sign up because I can't get the script to validate that an orgcode exists first... Subsequently, the general public being who they are put passwords in orgcodes, orgcodes in passwords etc...
I have followed the instructions laid out by Jason B and I can't get it to work, mainly, due to the fact I have NO IDEA how to "filter the orgcode column on the posted orgcode form element."
Can someone explain what that means to a dumb ass like me please?
Here is my final code...
<?php require_once('../Connections/Users.php'); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_Scripts_PHP.php"); ?>
<?php require_once("../WA_ValidationToolkit/WAVT_ValidatedForm_PHP.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
$colname_orgcode = "-1";
if (isset($_POST['orgcode'])) {
$colname_orgcode = (get_magic_quotes_gpc()) ? $_POST['orgcode'] : addslashes($_POST['orgcode']);
mysql_select_db($database_Users, $Users);
$query_orgcode = sprintf("SELECT * FROM orgcode WHERE orgcode = %s", GetSQLValueString($colname_orgcode, "text"));
$orgcode = mysql_query($query_orgcode, $Users) or die(mysql_error());
$row_orgcode = mysql_fetch_assoc($orgcode);
$totalRows_orgcode = mysql_num_rows($orgcode);
if ((((isset($_POST["Register"]))?$_POST["Register"]:"") != "")) {
$WAFV_Redirect = "access-denied.php";
$_SESSION['WAVT_register1_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateNM($totalRows_orgcode . "",-1,0,"",",.",true,1);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"register1");
// *** Redirect if username exists
$MM_flag="MM_insert";
if (isset($_POST[$MM_flag])) {
$MM_dupKeyRedirect="duplicate.php";
$loginUsername = $_POST['emailaddress'];
$LoginRS__query = sprintf("SELECT emailaddress FROM users WHERE emailaddress=%s", GetSQLValueString($loginUsername, "text"));
$LoginRS=mysql_query($LoginRS__query, $Users) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
//if there is a row in the database, the username was found - can not add the requested username
if($loginFoundUser){
$MM_qsChar = "?";
//append the username to the redirect page
if (substr_count($MM_dupKeyRedirect,"?") >=1) $MM_qsChar = "&";
$MM_dupKeyRedirect = $MM_dupKeyRedirect . $MM_qsChar ."requsername=".$loginUsername;
header ("Location: $MM_dupKeyRedirect");
exit;
$editFormAction = $_SERVER['PHP_SELF'];
if (isset($_SERVER['QUERY_STRING'])) {
$editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "WAATKRegistrationForm")) {
$insertSQL = sprintf("INSERT INTO users (emailaddress, password, orgcode, receiveEmails) VALUES (%s, %s, %s, %s)",
GetSQLValueString($_POST['emailaddress'], "text"),
GetSQLValueString($_POST['password'], "text"),
GetSQLValueString($_POST['orgcode'], "text"),
GetSQLValueString($_POST['receiveEmails'], "text"));
$Result1 = mysql_query($insertSQL, $Users) or die(mysql_error());
$insertGoTo = "thank-you-for-registering.php";
$insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
$insertGoTo .= $_SERVER['QUERY_STRING'];
header(sprintf("Location: %s", $insertGoTo));
Thanks,
Ted
so, you want the registration to go through only if the orgcode that was entered already exists in the users table?
The recordset is correctly set up to check if the orgcode exists, the issue in the validation.
The numeric validation is currently set to make sure the orgcode recordset is empty.
you need to change the numeric validation. Set the minimum to 1, leave maximum blank.
This will make sure that validation passes only of the orgcode recordset is not empty.
fdotmedia
Thanks jason...
Once again you've saved me...
glad to hear it is working.
fdotmedia
Btw... I have a small problem inside this site...
I'm building an elearning area and trying to pass in the product and step - like this:
blah.php?product=product&step=1
I can't get the product to read the right information...
It seems pretty easy and basic, I'm alot of things but smart is not one of them...
Any help would be great...
Thanks,
Ted
Please provide more details.
What is the actual result you are seeing?
What is the expected result?
What have you tried to accomplish the expected result?
fdotmedia
What I've Done
In my mySQL script I'm LEFT JOIN ing my user db and the product db...
I'm using SecuityAssist to write the session variables; user id email address, product id, product title...
The Idea
The idea is a user, "john doe", has an associated product, "elearning".
I'm trying to filter the results to display "john doe" "elearning" and the steps that are associated with the product...
blah.php?product=elearning&step=1
What I get
I'm actually seeing nothing, I get an error and a blank white screen...
? any help would rock!
what is the error? I need all of the details to be able to help.
If you are not getting any error, ad d the following code at line 1 to turn error reporting on:
error_reporting
(E_ALL);
it would also help to have a copy of your page.
