Can you add fields to dataAssist pages through the whizard after pages created?
Thread begun 8/04/2010 6:01 am by matt360561 | Last modified 8/04/2010 10:37 am by Eric Mittman | 1415 views | 1 replies |
matt360561
Hi
Is there anyway or adding an extra field through the whizard to a dataAssist page that was already been created? Sometimes on the insert screens I've seen the server behaviour in DW and double clicked it and it sees the new field added to the form and can add it to the query. It diens't always appear in the server behaviours panel though and not for the update pages. It's quite fiddly having to go in and do it manually and I'm sure there must be an easier way using the dataAssist extension.
Any advice greatly appreciated!
The DataAssist wizard only creates the set of pages, you cannot go back into it. It will create the insert and update pages based on the fields that you have specified in the wizard. If you have additional fields and would like to only generate a new update or insert page you can run the wizard and uncheck the other pages that you don't need. Other than this you will need to manually edit the insert and update pages to add in other fields.
