Images still will not display
Thread began 8/03/2010 7:22 pm by koerbcm | Last modified 8/04/2010 5:20 pm by Jason Byrnes | 1002 views | 8 replies |
koerbcm
Followed the instructions for uploading pictures and it will not display on my site, nor does it add anything into the database. I never seem to have any luck with this type of thing.
adminproducts_insert.zip
to start troubleshooting the issue lets use the insert page. change the following line:
$WA_redirectURL = "adminproducts_detail.php";
$WA_redirectURL = "";
so that it will not redirect when a new record is inserted.
then at line 1 add the following code:
error_reporting
(E_ALL);
ini_set('display_errors''on');
next, go to the bindings panel, and add the debug info binding from the WA Uploaded Files Global Status group to the page.
post back the results after trying another test.
koerbcm
The two lines that i was to replace are the same, and i don't know what you mean by the binding. I usually add that debug code to the top of the page. Is that what you mean? I am a bit confused. sorry
koerbcm
After I add the debug code to the top of the page, this line shows up when it loads.
Notice: Use of undefined constant php - assumed 'php' in /var/www/vhosts/coloradomountainstickers.com/httpdocs/t_server/cmsadmin/adminproducts_insert.php on line 103
After it is submitted, it goes to the detail page, with nothing displayed in the thumbnail or image fields.
sorry, I was typing to fast.
the chagne to the redirsect url should be:
the error reporting code should be:
error_reporting
(E_ALL);
koerbcm
After i try to submit the form this is what shows up.
Warning: move_uploaded_file(/var/www/vhosts/coloradomountainstickers.com/httpdocs/t_server/cmsadmin/../images/originals/8fab3609d29f8fb045b2e32a461d35e8_tmp.jpg) [function.move-uploaded-file]: failed to open stream: Permission denied in /var/www/vhosts/coloradomountainstickers.com/httpdocs/t_server/webassist/file_manipulation/helperphp.php on line 96
Warning: move_uploaded_file() [function.move-uploaded-file]: Unable to move '/tmp/phpQq3KpJ' to '/var/www/vhosts/coloradomountainstickers.com/httpdocs/t_server/cmsadmin/../images/originals/8fab3609d29f8fb045b2e32a461d35e8_tmp.jpg' in /var/www/vhosts/coloradomountainstickers.com/httpdocs/t_server/webassist/file_manipulation/helperphp.php on line 96
Warning: copy(/var/www/vhosts/coloradomountainstickers.com/httpdocs/t_server/cmsadmin/../images/originals/8fab3609d29f8fb045b2e32a461d35e8_tmp.jpg) [function.copy]: failed to open stream: No such file or directory in /var/www/vhosts/coloradomountainstickers.com/httpdocs/t_server/webassist/file_manipulation/helperphp.php on line 98
the error means that the permissions on the /images/originals/ folder that the images are being uploaded to do not allow write access.
you may be able to change the permissions in Dreamweaver. In the files panel select remote view, right click the /images/originals/ folder and select Set Permission. check the read and write boxes for all three user types.
koerbcm
That worked. Thanks.
you're welcome.
