Error on new istall of PowerStore3 logging in
Thread begun 7/28/2010 4:13 pm by admin140217 | Last modified 9/15/2010 9:44 am by Jason Byrnes | 4077 views | 9 replies |
admin140217
I have just installed PowerStore 3 and am getting an error when I go to the Admin login, the error is below:
Parse error: syntax error, unexpected T_STRING in /hermes/web01b/b1067/moo.servername/PowerStore300/WA_Globals/WA_Globals.php(58) : eval()'d code on line 1
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /hermes/web01b/b1067/moo.servername/PowerStore300/WA_Globals/WA_Globals.php(58) : eval()'d code:1) in /hermes/web01b/b1067/moo.servername/PowerStore300/WA_eCart/WA_eCart_Definition_PHP.php on line 480
This is a new install as it came out of the box but I'm not sure of where the error is. I can supply the URL is needed but I was hoping someone knew the answer to this one.
change line 58 of the WA_Globals/WA_Globals.php file:
eval("\$WAGLOBAL_".$value[$x][4]."='".replaceTokens($value[$x][1],$tabs)."';");
eval("\$WAGLOBAL_".$value[$x][4]."='".addslashes(replaceTokens($value[$x][1],$tabs))."';");
admin140217
That seems to have done it Jason, thanks!
You're welcome, glad to hear it is working.
carleneBeta Tester
I'm having the same issue is this due to the PHP 5.3.0 version failing if the session fails to start?
I did the fix but am still getting this error:
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /Applications/MAMP/htdocs/wholesale/store/users_Registration_full.php:5) in /Applications/MAMP/htdocs/wholesale/store/WA_eCart/WA_eCart_Definition_PHP.php on line 480
I'm testing locally on MAMP with PHP 5.3.2.
the error is reporting output to the page on line 5 of the users_Registration_full.php page. Please send a copy of that page in a zip archive so I can check the code.
carleneBeta Tester
Thanks Jason!
I of course was customizing this page and adding encryption to the Password field. Have no idea if I've messed it up somehow now.
there is a blank space at the end of line 4 that is causing the problem, it is just after the ">" character:
remove that blank space to fix the error.
carleneBeta Tester
Darn those blank spaces!!
Thanks so much Jason - I doubt I would have found that on my own! It's been driving me crazy. That error is gone now.
However -- when I fill out the form and push Register - I'm getting this error on the page:
Deprecated: Function split() is deprecated in /Applications/MAMP/htdocs/wholesale/store/WA_ValidationToolkit/WAVT_Scripts_PHP.php on line 330
Deprecated: Function eregi() is deprecated in /Applications/MAMP/htdocs/wholesale/store/WA_ValidationToolkit/WAVT_Scripts_PHP.php on line 547
Column 'UserGroupID' cannot be null
I googled this and apparently the split( call doesn't work in PHP 5.3 and I should replace it with explode( ???
Ok - where do I do this?
none of the power store 3 files use the split function, did you use Validation toolkit to make updates?
Download a fresh copy WA_ValidationToolkit/WAVT_Scripts_PHP.php file from the powerstore 3 download center.
