Error initializing menu object
Thread began 7/28/2010 1:11 pm by mgreg378555 | Last modified 7/29/2010 9:27 am by Eric Mittman | 1882 views | 1 replies |
mgreg378555
Hello,
When trying to create either a site using SiteAssistPro108 or SiteSculptor100 and basing myself on a custom made layout by CSS Scultor301 i get the following error
(wa.generate.getMenuSettingsObject):
Error: getDocumentDOM: Argument number 1 is invalid
When I try to place the menu in the topNav bar
How can this be corrected?
You may need to clear out your cache file with the instructions here:
If you still have this problem after clearing the cache file it is possible that there is a problem with the configuration folder. If that is the case you will need to follow the directions here to have a new configuration folder created for you.
showpost.php?p=12293&postcount=2
If the problem persists please let us know so we can open a ticket for you on this issue.
