How to Customize Checkout Pages
Thread began 7/28/2010 3:37 pm by wilyumcj205276 | Last modified 7/29/2010 1:23 pm by Jason Byrnes | 602 views | 3 replies |
wilyumcj205276
Where can I find instructions on changing the design of all checkout pages generated via the Checkout Wizard. I would like to change the credit card expiration to a drop down list. When the client clicks "checkout" they need to be forwarded to a login page/new user login page. How is this done when using the checkout wizard? Will I have to manually change code to do this? Is this all done via CSS? Again, where can I find comprehensive instruction? Thanks!
William
there is a tutorial on the eCart suport page for adding login / register functionality to the eCart checkout page.
ecart/
There is not documentation for converting the cc expiration year checkout form element. It is a simple process though.
Make note of the existing cc expiration year form element, delete it, then insert a list form element and give it the same name.
wilyumcj205276
Thanks Jason. You answered 2 of the 3 questions. I need to know how to change the visual design of all checkout pages. I have gone into the CSS panel and changed some things, but it's hit or miss. Is it all CSS?
yes it is all css. you need to edit the eCart css files to change the visual design.
