installing GD Image Library & cURL
When i run the installation wizard is says GD Image Library and cURL are not installed. How do I install these? I am running a Linux Server with Plesk 8.1
they must be compiled when you build the PHP install package for linux.
you will need to refer to the php.net instruction for installing php in linux there should be a section there on compiling additional libraries.
