Content management
My client asked me to delete the FAQ's page from the content management in PowerStore 3.
How can I put it back in as he now wishes to use it.
I still have the page itself on the server but it no longer appears in the CMS system.
Did you remove just the faq section of the footer pages or did you remove the link to the faq page from the footer area of the main template?
To add it back into the footer pages you will need to add it directly to the db. In your db in the ps3_contents table add in a record with these values:
ContentID: no value needed, it will auto populate
ContentGroup: Footer Pages
ContentRefID: FAQ
ContentValue: just add some place holder text here
ContentDate: no value needed, it will populate automatically when you update it
When you add a record like this to your ps3_contents table it should give you back the FAQ area in the footer pages.
