How to edit Profile Page
How do i edit the Profile page that gets created with The Security Assist Wizard - I do not see a Update Record behavior? Would like to add another Field.
thanks,
thanks,
By default the update and inserts that are created by Security Assist are the standard DW versions. You can edit these directly from the server behaviors tab of the application panel. You can also replace them with the DataAssist version of the server behavior for greater flexibility.
In the Security Assist support page under Solution Recipes you can find some tutorials on updating these server behaviors with the DataAssist versions.
securityassist/
