Map loading with a starting address
Thread began 7/26/2010 6:01 am by siteontime | Last modified 7/27/2010 7:10 am by Jason Byrnes | 795 views | 3 replies |
siteontimeBeta Tester
I have set up a directions page to the get map address dynamically for 7 locations. Four of the locations load properly, but 3 of them load with a starting address in Kansas.
This link shows the starting address, which it shouldn't
Directions.php?Store=3
This one does not show a starting address, which is correct:
Directions.php?Store=1
I am not sure where the starting address is coming from.
Thanks for the help.
if you look at the source, the country is hard coded to us:
var fromAddress = {
enabled: true,
street: '',
city: '',
state: '',
zip: '',
country: 'US',
full: ', , , , US'
so the starting directions will be the middle of the US. do not hard code the country to avoid this.
That was it! Thank you for the fast reply. I appreciate it.
One other quick question: How do I get the pop up address window to display on page load?
it is not supported to show the info balloon when driving directions are included.
