Link an email address that is loading dynamically
Thread began 7/25/2010 7:15 am by elewis93815 | Last modified 7/25/2010 1:42 pm by elewis93815 | 907 views | 4 replies |
elewis93815
How do you have an email address linked in a dynamically loaded page:
Deb Albersman
1300 Nicollet Mall Suite 3024
Minneapolis MN 55403
Off. (612) 673-0347 Fax. (612) 673-9301
debalbersman@aol.com
Jag Jeans (M) Updated missy jeans, crops & shorts...that really fit SPOR, PETI, XSIZ
Here is a link to the page: exhibitorsTEST.php
Thanks for any help.
Erick
neilo
Hi Erick,
You would just need to add the <a href="mailto:"></a> tags to your email dynamic text line. So, if your email php line looked (something) like:
<td><?php echo($row_yourRecordset['email']); ?></td>
You would add the link tags, so:
<td><a href="mailto:<?php echo($row_yourRecordset['email']); ?>"><?php echo($row_yourRecordset['email']); ?></a></td>
elewis93815
Still having problems
Thank you for your reply but I am still having problems getting this to work. Seems pretty straight forward, however....
Here is the exact code that I'm using. The second portion has to do with the website address that is also included on that same line, we do not need the website address to be linked, just the email address....
<td bgcolor="#FFFFFF" class="WADAResultsTableCell"><?php echo $row_WADAnorthstar['Email']; ?> <?php echo $row_WADAnorthstar['Website']; ?></td>
Thanks!
neilo
Hi Erick,
Not sure why that didn't work; - with the code you supplied (and just the email address linked) the revised code should be:
<td bgcolor="#FFFFFF" class="WADAResultsTableCell"><a href="mailto:<?php echo $row_WADAnorthstar['Email']; ?>"><?php echo $row_WADAnorthstar['Email']; ?></a> <?php echo $row_WADAnorthstar['Website']; ?></td>
Give it another try and see what happens.
elewis93815
It worked, Thank You!
I did in fact use the exact code that you just sent and it worked. Not sure what happened the first time, but were set now.
Thank you very much!
Erick
