Basic File Upload Problem
I'mtrying to upload an image file and place the filename in a database record field.'ve followed the 5 page pdf tutorial but the options mentioned don't exist.
Basically
i created a form with a text fiield and submit button which worked OK.
I then made the text field hidden and created file field and applied the file manipulation upload behaviour
Then changed the update behaviour to use the new file field
This seems to follow the 5 page pdf instructions but the database is never updated.
Any help appreciated as I'm sure this should be an easy thing to do.
Test webpage is here: upload_test.php
Clive
