Captcha Name
hi,
does the captcha image always have to have the name captcha_1
what if, i want to use 3 diffrent captchas on my site?
do i have to rename them on my own?
I looked at the code, there ist captche_$field or something.
Denis
hi,
Denis
You can add another argument to the url to effect the session variable for your captcha...
so if you used:
WAVT_CaptchaSecurityImages.php?field=2
Then it would create captcha_2
By default it uses 1, but you can add as many unique ones as you want. Field can be any combination of letters or numbers that are valid as session variable names.
