Upload File Renaming
Hello ,
I wonder, what should i do so the uploaded file to be renamed to something like a big number for example 120263.jpg ?
Hello ,
You can try using a php function to generate the file name. For example you can use the session_id which is always unique, or yo can try using a time stamp. In both cases you might need to do some trimming because both of those numbers are very big.
