Slight glitch in IE6
Thread began 7/13/2010 9:22 am by iainmacdonald331081 | Last modified 7/16/2010 12:14 pm by Eric Mittman | 2042 views | 5 replies |
iainmacdonald331081
Hope someone can help with this...
I have a page here :
index.shtml
It all looks as it should, except in IE6, where there's a gap of about 3 pixels between the menu / left hand column and the main content.
I had assumed I just need to tweak the left column width and or main content left margin for IE6, so had been playing around with them as conditional CSS :
<!--[if IE 6]>
<style type="text/css">
#outerWrapper #contentWrapper #leftColumn1 {
width: 214px;
#outerWrapper #contentWrapper #content {
margin: 0 0 20px 214px; /* Sets the margin properties for an element using shorthand notation (top, right, bottom, left) */
</style>
<![endif]-->
..but whatever I try, I can't seem to get rid of the gap....
Also - whilst anyone is there, it would be great if you could quickly let me know if the navigation styling in IE6 looks the same as it does in other browsers.
Thanks again.
I have been looking into this a little and it seems that the conflict might be coming from some styling that is applied to the content div. It seems that when I get the page to have only this side nav area and the content the problem is still present, but when I remove the content div it gets rid of the spacing.
I have not found a setting that makes it all correct but I think this is where you should be looking. If you have not done so already you may want to try adjusting one of the padding or margins to a negative value to see if it has any better effect for you.
iainmacdonald331081
Thanks Eric - I'll have a look at that.
Were you able to quickly check the menu styles in IE6? I did have an old PC, but no longer have it, so have been relying on Adobe's browser lab, but it just shows static shots of a page's initial state.
I too do not have a native Windows environment for testing in IE6, I have made use of IE tester that allows you to render pages in previous versions of IE. There is also a developer tools add in that lets you inspect aspects of the page.
I did not notice any problem with the menu rollovers but I was not really looking for any. Nothing catastrophic that I could see.
Dave BuchholzBeta Tester
Try this link for more info on this issue alternatively try googling "IE 3px jog"
Thanks for the info, very helpful.
