two shipping methods using eCart 5?
Thread began 7/12/2010 9:29 am by jsnwang89407861 | Last modified 7/13/2010 10:08 am by Eric Mittman | 769 views | 1 replies |
jsnwang89407861
I have two pre-selected shipping methods, UPS overnight for category I products, and UPS Ground for category II products.
If customers order category I products, no matter how many, I will charge them one package shipping expense based on UPS real time quote.
If customers order category II products, no matter how many, I will charge them one package shipping expense based on UPS real time quote.
If customers order both category I and II products, no matter how many, I will charge them one package shipping expense for category I (UPS overnight), plus one package shipping expense for category II base on UPS quote (UPS ground).
How could I achieve my goal by eCart 5? Is UPS real-time quote possible with two shipping methods used at the same time?
Thank you for any input.
The shipping quote server behaviors will not work this way by default. How the server behaviors work is to interact with the shipping quote server go get a quote based on the values you have specified. When the quote is retrieved it is stored in a session variable. It is this session variable that is used for the shipping charge for that particular rule, so it is designed to work with only a single quote per order and provider.
If you had two of the shipping quote server behaviors on the page and managed to set them to save the value in different session variables you could implement the shipping like you have described. This would be a custom process though and it would force you to update the source code for the shipping quotes to make it all work. If it is something that you feel up to you should give it a try, but you will need to know some basic php coding and how to deal with session variables.
