Jimmy:
First off, I apologize for not responding sooner. I have "instant notification" checked and never received ANY notification, let alone "instant". So, sorry about that, and thanks for responding.
Here is what I want to accomplish:
1) I have one dedicated ipAddress for my antiMall.org domain.
That is where I installed PowerStore3.
2) It has three domains that share its ipAddress which are the stores, each with their own databased products and store "look-and-feel".
3) All stores will use the same shopping cart, customer registration/authentication, payment authorization, and check-out.
4) So, the mall is "common" and the stores are distinct in how their web pages look. When you "walk" into a store, the CSS/XHTML will make it look different than the common mall and other two stores. What is available is only available in that store. You select an item or two, take your cart out into the mall again, and either check out or go into another store with that same cart. make sense?
So, I need to know how to install PowerStore and my Super Suite extensions, and where, such that I can share the common pieces and also make unique the store "ambiance" and availed products.
I despise stores that have everything in them competing for your eye; they're confusing and demeaning. Each store has a theme, like a restaurant would have.
Do I need to setup Powerstore3-accessible databases for each store and have what database is being looked at depending on which store is entered?
I could still use the same registration and shopping cart until that user logs out, right?
So, how do I distinguish a single store, and where?
Right now I log in as admin only.
It's setting up a test user that I need to let go into 2 stores, each with its own database (or section of a database) with one cart.
I need to know what pieces/modules are affected, where they reside, and what code to look for.
I see no code documentation, no module descriptions, no variable descriptions. Where is that basic code documentation kept or what would you suggest for mapping module data flow?
I need to map what may not be mapped. It's going to be very helpful to know system integration of modules, and what goes on inside the modules I am dealing with. At Intel, Mentor Graphivcs, and Network General, every module had a header that could be accessed. Maybe I can run a script to grab those headers so I can discover the info? Suggestions are very much appreciated.
Thanks Jimmy!
best wishes,
chris
