template brokes entire website
Thread began 7/08/2010 4:10 pm by romeo370381 | Last modified 7/12/2010 4:27 pm by Eric Mittman | 1504 views | 5 replies |
romeo370381
Dear,
I am using the new version of universal email, and whenever I use a template that I create myself and add a query in order to add some of the data dynamically, it doesn't work and in fact, breaks the entire website with a fatal error,
Is there a way to add data dynamically,
Because, when I try to use the edit, and use a dreamweaver empty page, the date doesn't display correctly I get the all php request instead of the data itself,....
So basically, the extension is turning useless in some how.
Sincerely,
R.
Please detail the exact steps you are taking to configure your email and the results that you are getting versus what you are expecting.
What is the fatal error that you are getting?
romeo370381
The thing, I am using the "Create file for your email" option, first I tried to create a file and add content dynamically, as soon as I did put the files online, I couldn't see anything of my site, the index page diplaid completly blank, with no text or images.
As soon as I take the dynamic input of, everything works again,
I even used you pre-maid templates that come with the extensions, and did the same thing, so neithetr yours or my selfmaid works,
could you let me know how I can solve this, because using the templates without be able to enter some data dynamically seems quite useless for me, personally.
Thanks.
If a page displays as blank it usually means that there are errors on the page and php error reporting is turned off. You can enable php error reporting on the index page by putting this code at the top of the page:
error_reporting
(E_ALL);
This should allow you to see the errors that are occurring. If you have the same result after applying this code to your index page you may need to talk to your host about enabling error reporting in php.
romeo370381
Here is the error I even got locally after I added the show error code:
This is because, I added dynamic data to the template, it does the same evemn when I create a page from scratch,...
Warning: session_start() [function.session-start]: Cannot send session cookie - headers already sent by (output started at /Applications/MAMP/htdocs/test_newsletter/index.php:7) in /Applications/MAMP/htdocs/test_newsletter/index.php on line 8
Warning: session_start() [function.session-start]: Cannot send session cache limiter - headers already sent (output started at /Applications/MAMP/htdocs/test_newsletter/index.php:7) in /Applications/MAMP/htdocs/test_newsletter/index.php on line 8
These errors are telling you that you there is output that has occurred on line 7 of your index page. Due to this output the header call on line 8 will not be executed. What do you have on line 7 in this file? Usually when you see this error it is due to some white space characters being outside of the php blocks. Check the php blocks you have near this line and make sure to update them if there are any spaces or returns present.
If you can't spot it and continue to get the error post back with a current copy of your index page that is producing this error in a zip archive so that I can take a look at it.
