dynamic add-to dropdown
Thread began 7/06/2010 4:16 pm by rick178787 | Last modified 7/08/2010 7:10 am by rick178787 | 854 views | 6 replies |
rick178787
I have several tables where, particularly in the beginning, users may not find the correct LABEL in a dataset and need to add it. These dropdowns are part of a larger form.
In Developer Toolbox we had a little server behavior we'd apply to a predefined dropdown generated from a RS that would allow a user to type and add an item to the dropdown list and then reload the list for selection and insert/update.
I'm thinking I could do something with WA triggers, but I can't find a way to call them if I've used a simple DA Wizard form. Am I just missing the insert trigger? The understanding triggers pdf doesn't address how to access them independent of a larger tool, like eCart.
Should I just move on to JQuery instead and save some time? You'd think that this is the kind of little server behavior people would use all the time.
I'm not sure that I understand what type of instruction you are looking for. Triggers are just used by the server behaviors for determining when to execute the code for that server behavior. So if you have a special trigger for the insert then only when that triggers conditions are met will the insert occur. In this context what would you like the trigger to do for you?
If you are looking to add in functionality on change of a select list this would be a client side behavior, not a server behavior. You should be able to select the element and go to Tag > behaviors to set an action for the event of that form field. You will not be able to trigger server behaviors directly like this though.
rick178787
I'm trying to do this:
basic.php
add an item to a dropdown on the fly.
The page you linked to uses client side jquery to achieve this result. This is not something that you will be able to configure using any server side triggers by themselves. If you had the form submitted with some client side js you could use the values that are submitted with the form to trigger a particular server behavior, then have the page redirect back to itself after the record has been added. Since the list is drawn dynamically you should only need to insert the record and reload the page to see the change take place.
rick178787
Well, groups like WA and Interakt have been blurring the meaning of SB for a long time now. But you are right, it is a client side / server side combo widget. What should I call it?
What I should have said is that the Interakt/DTB widget was applied through the SB flyout in the Database window/SB tab. Still it was quite useful (and fast to apply).
So really there's no quick way to do what I want with WA and I'd be better off picking up the JQuery?
There is no single behavior that you can make use of in the WA tools that would do this for you. It would require you to use client side scripting to submit the form onchange of the menu. Then use the posted values to trigger the server behavior that will insert or update the record, then redirect back to the page.
It is really the functionality of an insert or update server behavior that you need, you would just like to trigger it based on a client side event rather than the typical form submission. Other than submitting the form with the client side js it is the same as a standard insert or update server behavior.
rick178787
Sorry to bother you.
