Javascript Error w/ UE 3.0.7
Thread began 7/06/2010 12:27 am by zuffster370186 | Last modified 7/07/2010 7:08 am by Jason Byrnes | 1531 views | 3 replies |
zuffster370186
I was having this error with UE 3.0.6 when I realized 3.0.7 was available. I uninstalled 3.0.6 and installed 3.0.7. Javascript error was gone and I was able to insert the UE Server Behavoir. Later went back into the page to update a few things and noticed the UE server behavoir had a red exclaimation mark next to it. When i clicked on it, I got this javascript error.
I already deleted the cach file as i often must do with your extensions and I still get this error. Even after closing DW, deleting the cache file, rebooting DW and it is still there.
What is going on with this Universal Email ext?
can you send screen shots showing your site definition settings for the testing server and local info tabs? This may help determine the cause of the problem.
zuffster370186
Jason, please see the attached. I hope I provided you with the correct screen shots.
Also I was able to copy this code the DW CS3 is showing when DW crashes because of this:
Problem signature:
Problem Event Name: APPCRASH
Application Name: Dreamweaver.exe
Application Version: 9.0.0.3481
Application Timestamp: 4600622f
Fault Module Name: MM.dll
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 46005cf1
Exception Code: 40000015
Exception Offset: 00008943
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 1033
Additional Information 1: fde6
Additional Information 2: bfb9e96820df8300c5eedb67d418c279
Additional Information 3: 5ac3
Additional Information 4: 703d271d11736b0c101d285b92d6dd0c
Read our privacy statement:
?linkid=50163&clcid=0x0409
you also have another thread posted:
showthread.php?t=13065
in this thread you report a different error that is a result of a corrupted config folder.
this may be related to the errors you are reporting in this thread.
