Can't connect to gateway via Checkout Wizard
Thread began 7/05/2010 9:49 am by wilyumcj205276 | Last modified 7/06/2010 10:20 am by Jason Byrnes | 808 views | 1 replies |
wilyumcj205276
Still not able to run successful checkout wizard. The last step of the checkout process which is to select checkout button, is not selectable. Yesterday I was at least getting an error message that stated "unable to complete checkout process"
API creds are correct
Linkpoint .pem file is in a folder on server
How do you edit the server behavior, which I can't even find
I'm not sure I understand, are you having a problem running the wizard? or is the problem with the pages that the wizard generated?
The last page of the checkout wizard is to name the pages that are to be created.
are you saying that you cannot click on the checkout button on the confirm page?
API credentials are used by paypal checkout. the .pem file is used by Authorize.net.
Can you clarify what payment gateway you are using?
Which server behavior do you want to edit?
