DataAssist Search is not pulling anything back
Thread began 7/05/2010 11:55 am by elewis93815 | Last modified 7/05/2010 11:21 pm by tom250037 | 645 views | 3 replies |
elewis93815
I hope someone can help us with this:
We have created a basic search function pulling from one RecordSet (in the bindings). We created our Results page, then used the Search Wizard to create the "Search" function. When we test the Results Page, all records are there however, when we try to run a search, we get nothing, no errors, just the same screen showing the search field and search box. We have tried this process many times, started on a local host, thought that may have been a problem, but now trying "live" without luck on either.
Can anyone help, this seems to be pretty simple, we've done it many many times on other accounts.
Thanks,
Jackie
I've attached the files but please also review:
a_search.php
a_results.php These are the results that should appear but are not.
WA Data.zip
tom250037Beta Tester
Jackie,
The files you attached dont contain same files as your live site, so its hard to tell for sure, but I think you are just submitting your form to the wrong page.
your search form (a_search.php) is submitting the form to itself (ie the 'action' attribute of your form tag is a_search.php)
Try changing that to a_results.php, so it submits to the results page, and it should work.
ie change
<form name="form1" action="a_search.php" method="post">
to
<form name="form1" action="a_results.php" method="post">
Hope that helps
Tom
elewis93815
That worked!!!! Thank you!
That worked, I will admit that it's kind of embarrassing that it was so simple to fix, however that's how we all learn - THANK YOU!!!!
- Jackie
You are most welcome.
Glad I could help.
Tom
