search last name by first letter
Thread began 7/01/2010 3:02 pm by paulshoe379536 | Last modified 7/01/2010 9:20 pm by Jimmy Wu | 743 views | 3 replies |
paulshoe379536
I have a search page that I am using buttons for each letter of the alphabet (i.e. A,B,C,D..) to search for a person by the first letter of their last name. I created the page using the DataAssist Wizard and then modified the text box and submit button as follows:
For the "W" button
<form action="members_list2.php" method="get">
<input type="hidden" name="S_last_name" id="S_last_name" value="w" />
<input class="alphaBtn" type="submit" name="Search" id="Search" value="W" alt="Search" title="Search" onmouseover="this.className='alphaBtnhov'" onmouseout="this.className='alphaBtn'" />
</form>
This seems to be working fine. However, the DataAssist Web Validation tool complains because "S-last_name" and "Search" are defined multiple times.
Is this okay? If not, can you help me with the proper method?
Jimmy Wu
That should be fine, each of the letters has a different search form so the submission should be fine as well.
Another way that would get around this would be to have the search field be a hidden field and oh mouseover of the different letters the search field would be populated with the letter. That way the form will not be defined so many times. Setting it up the way you have it shouldn't be an issue either though.
paulshoe379536
thank you... as long as I don't have a problem, I'll move on to other things... I can come back to this later and tighten up the code using your suggestion...
Thanks again,
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
