Uninstalled CSS Sculptor and now get this error .
Thread began 6/30/2010 5:35 pm by nancy19533 | Last modified 7/01/2010 6:14 pm by Jimmy Wu | 1690 views | 6 replies |
nancy19533
every time I open Dreamweaver CS5.
Unable to find file WA_Memento.htm in the Configuration/Floaters directory. The floater will not be shown.
Click OK and there is a flash where that annoying little window was (no idea what it was) when I had CSS Sculptor installed.
How do I get rid of this? A search of my C drive has not found this file (which of course makes sense since it could not be found) but I now get the message above every time I open Dreamweaver.
Is this something left over from the extension or did CSS Sculptor trash my DW installation?
Thanks,
Nancy
You should delete the dat file to resolve this issue, here are the instructions for this:
Let us know if you continue to have the problem.
nancy19533
No .. sorry. I did that and still have the same problem with the same error message. Other suggestions? Please don't say reinstall Dreamweaver .. I have my custom workspace, extensions all installed, custom Snippets .. tons of things not to mention that it's part of the Master Collection.
nancy19533
Gave it one more try. This time, I deleted the WinCache.dat file and then I rebooted the computer just to see if that would help. It did not. Starting up Dreamweaver still produces the same error.
Where does the hook to WA_Memento.htm reside so I could go in and manually delete it or modify the file that is looking for it?
Thanks,
Nancy
Jimmy Wu
Try going to the menu Window->Workspace Layout->Reset '<current workspace' and see if that resolves the issue.
nancy19533
YES! Thank you so much! That did it!
Nancy
Jimmy Wu
Great to hear it. If you run into any additional issues, feel free to open a new thread.
