Moving a PS3 site from local testing server to live server
Thread began 6/29/2010 7:03 pm by marcus381392 | Last modified 6/30/2010 3:28 pm by Jimmy Wu | 728 views | 3 replies |
marcus381392
Hi I've now fifnshed developing my site using PS3 and I want to upload it to my live site (which is a shared hosting account) how do I move the database from my local computer to the hosted server.
Also do I have to do a fresh instal of PS3 first on the hosted server and then upload and overwrite with my developed site?
Jimmy Wu
I would recommend doing a fresh install on your hosted server so that the hosted variables are set up correctly. I would recommend keeping the wa_settings table without overwriting with the one from your testing server, or at least note the pg_root, pg_rooturl and Root URL from the wa_settings table on the hosted server.
Then you would want to make a backup of the database and import it to your hosted database. Then copy over those 3 rows into the wa_settings table.
You will also have to upload the imagesupload directory that should be in the root of your PowerStore.
marcus381392
Thank you for this information. How do I back up my database?
I'm using XAMPP to host locally on windows XP.
Thank you.
Jimmy Wu
I've actually never used xampp, but there should be a phpMyAdmin for that, where you would select your database and then export. Then on your live server you would do the same except you would import the file you exported from your local.
