Coupon on Highest Priced Item
Can you tell me how I can apply a coupon to the highest price item in the shopping cart?
There isn't a way to add a discount to the highest priced item in the cart. You would have to write some custom coding to accomplish this, so it wouldn't be something that is supported.
Thanks- I have all of the extensions that webassist offers. Is this something that could be done with ecart and some handcoding?
Could you possibly give me some ideas on how to do this?
One way you can set this up is to have a loop that figures out the highest priced item in the cart and sets a session variable to store the information. Then in the eCart object, you would want to add a discount rule that is based on if that session variable exists and total number of unique items is greater than 0. Then in the calculation you would set it to based on the quantity of an item. You would have to change the quantity of the item dynamically to match the highest priced item (more custom changes) after the changes are made.
