Multiple Currency
Does ECart or Power store have the ability to support more than one currency?
Can C$ be used or is it not supported as I suspect preventing me from buying?
you can use eCart to create a store that uses either dollars or pounds, or Yen.
But not a cart that supports more than one at a time.
Do you know if "US" is displayed or just a "$" on displayed product prices?
Hi
Sorry to join in without a real answer but just an idea.
You can have multiple carts on 1 site if Im not mistaken so although it would take more work on your part could you not use the same product database using different columns for the pricing in different currencies then depending on which currency the customer picks depends on the pages and add to cart buttons etc that are shown.
Using a session variable to store which currency the customer has chosen so the show region behaviour would know which buttons etc to show and use.
Possibly someone from WA would verify if they thought this was possible or not.
It would be a little complex. Just a thought.
Mike
the Dollar sign would be displayed for the prices.
As Mike H Suggested, you could create separate sites each with a different cart object using a different currency.
