How to edit a form
I need to add a new field but when I click to edit the form it does not pick up the form design. I need to add a drop down box and even if the form is selected it picks up some other design when I click edit contents.
Are there any other forms applied to the page other than the one you're editing? Could you zip up and attach the page you're editing so I can take a look at it?
You can see it at optionsforsuccess.net/vendorregister.php
I want to change add a field but can't seem to select it in DW. When it does get selected and when I do see the 'edit content' button (DWCS4) and select it it shows a different form. Also, if I wanted the form labels to display on the top instead of the side what would be the best method, I've tried changing measurements but it messes up the rest of the design. Thanks.
Can you zip up and attach your form to your next response so I can try to reproduce your error?
