Live paypal to paypal sandbox
Thread begun 6/27/2010 11:16 am by rafael.ordaz410005 | Last modified 7/19/2010 12:07 pm by Jason Byrnes | 5589 views | 13 replies |
rafael.ordaz410005
I recently setup the ecart 4.0 using paypal payment pro API credentials, later I learned they have differents API crendentials for the sand box.
How Can I swith to PAYPAL SANDBOX? I would like to perform test using the sandbox.
PayPal Payments Pro Uses 4 server behaviors over 3 pages:
checkout.php:
Authentication For PayPal Express Checkout
confirm.php:
eCart Local Checkout
pp_confirm.php:
Get payer Profile From PayPal Express Checkout
Process Transaction with PayPal Express Checkout
In the server behaviors panel, double click each of these server behaviors to change the API Credentials used and toggle the Use sandbox option.
rafael.ordaz410005
After updated the API credentials in:
checkout.asp
confirm.asp
pp_confirm.asp
pp_cancel.asp
pp_checkout_success.asp
I'm getting this error:
Microsoft OLE DB Provider for ODBC Drivers error '80004005'
[Microsoft][ODBC Microsoft Access Driver] Operation must use an updateable query.
/confirm.asp, line 67
this error is happening on the store order summary or details behaviors.
I will need to see your confirm.asp page to examine the code.
rafael.ordaz410005
File attached
the error is occurring on the following line:
WA_editCmd.CommandText = "insert into " + WA_table + " (" + insertParamsObj.WA_tableValues + ") values (" + insertParamsObj.WA_dbValues + ")";
see the following page for details on the cause and solution to this problem:
how-do-i-solve-operation-must-use-an-updateable-query-errors.html
rafael.ordaz410005
Jason,
The database permissions on asp seems to be solved, I'm still waiting for their confirmation.
I'm stuck now on "checkout_failure.asp" with this message...
Transaction Not Completed
We're sorry
Your transaction could not be completed.
thanks
see the "Debugging eCart transaction failed issues" tutorial on the eCart support page:
ecart/
rafael.ordaz410005
Paypal technical support is asking to which url is being passed the transaction. (Paypal's url address)
How can I now that?
if you have the use sandbox option selected, it will post to:
2.0/
otherwise the transaction will post to:
2.0/
if you add:
<pre>
<?php var_dump($_SESSION); ?>
</pre>
to the failure page, the URL being used should be somewhere in the session contents.
