Registration process not populating database
Thread began 6/24/2010 5:14 pm by gail.bergan407744 | Last modified 7/08/2010 12:05 pm by gail.bergan407744 | 1381 views | 9 replies |
gail.bergan407744
Hello again,
After getting my password problems resolved, I have a new problem. I uploaded all pages to my site and tried the simple registration page. After hitting Register, I do get the "thank you for registering, please click on the link in your email inbox" page. I click on the link in the email to verify the email address, then get the "thank you for verifying, now please log in" page. When I try to log in, I get the error: "The login information provided is not valid, please try again." Also when checking the database, I see that a user did not get added to the database.
I get this same error whether or not I have a standalone "Users" database (built by executing the .sql script in phpmyadmin) or by going through the same procedure, but adding a "users" table to a preexisting database. When trying the two different databases, I was careful to change the database name in the localhost connections file, and reupload that.
Any ideas? Would it help to look at any of my files? If so I would be happy to attach.
Thanks,
Gail
Jimmy Wu
One test that you could try is to manually add the user into the database and then trying to login using that user that you generated. This will help determine if the connection is successfully being made to the database. Also, can you provide a link to the pages so I can try the behavior myself?
gail.bergan407744
test worked
Excellent suggestion on manually adding a user (myself) to the database...I did this, then logged in. It successfully pulled up my profile (users_Profile.php). So something is wrong with my registration/verification pages, it would seem. The pages you could test yourself are users_Registration_Simple.php, users_Registration.php, Users_Confirm.php, etc. By the way, I am connecting with my preexisting membership database, with your users table added as a second table (rather than Users as a standalone database).
One question on the verification, registration, and lost_password.php universal email pages provided in the solution pack. I assume I am to move them out of the templates folder and into my main directory (after doing a SaveAs)? Or should the verification process be pointing to WAUE_users_EmailPW_1, WAUE_users_Profile_1, and WAUE_Registration_1 pages? It wasn't clear in the documentation what we were to do with these templates once we customized them.
Jimmy Wu
You would want to leave all the pages with the same structure as when you downloaded them, so you shouldn't be moving them around or you will affect some of the paths.
As long as your connection file is pointing to the correct database, you shouldn't have any problem with having any other tables in the database. It looks like the process that is being skipped is the insertion into the database. Is anything getting inserted into the database or is it not getting populated at all?
To check the insert query, find this line of code in the users_Registration_Simple.php file:
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
After this line, add this line:
die($WA_Sql);
Then run through the registration again. Post back with what is displayed on the page.
gail.bergan407744
I added the code as you suggested. I still get:
"The login information provided is not valid. Please try again."
Gail
gail.bergan407744
As a PS to my previous message, when I try to register a user who is already in the database, I get the message "that email address is already registered." So it seems to be connecting/reading the database OK, it's just not inserting anything new.
Gail
Jimmy Wu
That's interesting, the sql statement that is being used isn't being displayed onto the page at all?
When you're registering are you using the users_Registration_Simple.php or just the regular users_Registration.php page?
gail.bergan407744
I stated in my original posting that I'm using the simple registration form. I don't understand your question about the sql statement. I'm relaying to you all error messages that I see on the screen.
I'm desperate to get this up and running...have been fighting for 2 weeks with URSP and seem to hit roadblocks at every stage.
Jimmy Wu
I'm not sure I see where you stated that you're using the simple registration form. You have both registration forms referenced in the second post you made.
Have you made additional modifications to the page or the database since I last posted? It looks like when I access the simple registration form, I get a sql error now. Here is the error I am getting on your simple registration form:
Unknown column 'UserID' in 'field list'
Could you attach the current code for that page?
gail.bergan407744
I've been forced to abandon this product. After two weeks of struggling trying to get it to work, I built a simpler login solution from scratch. My hosting service told me that one issue may be that your fields in your Users table are not all lower-case, but camel-case (i.e., UserID instead of user_id) and that upon transferring to our server, the case issue becomes a problem. Since all your scripts would have to be edited if I changed all fields to lower case, I decided this would cost me an additional amount of time that I just can't invest. They may be right or they may be wrong, but at least I have something that works now.
