Menu Writer + Analytics Event Tracking ??
Thread began 6/21/2010 6:41 pm by gregb440246884 | Last modified 6/22/2010 8:31 am by Jason Byrnes | 1225 views | 3 replies |
gregb440246884
Is there any way to use Google Analytics Event Tracking with Menu Writer Menus? I would like to add the onClick code for event tracking to all of my navigation menu buttons... is there any way to do this?
you will need to manually add the onclick code to the menu links after the menu is created.
gregb440246884
Correct my if I'm wrong, but after looking at it a bit closer last night... it appears all of the menu links are held in the .xml file.
I'm guessing the php script (or javascript) builds the html for the page on the fly... in which case it 'may' require some custom coding / changing of the Menu Writer php/java to add the Analytics Event Tracking code, since this needs to go inside of the <a> tag for the link...?
I'm fearing that there is no current method within menu writer to have it add additional code to the links themselves... in which case if I want to use Analytics Event Tracking, I'm going to have to build the whole menu by hand in the html... since I am most certainly not a php or javascript programmer!
no, the links are contained in the menu.php file.
you need to edit the link code in the menu.php file manually to add the onclick event.
