Coupons to Add Products
Thread began 6/21/2010 3:32 am by mr. graphic | Last modified 6/29/2010 1:18 pm by Jimmy Wu | 1708 views | 17 replies |
mr. graphic
as I was testing PS3, I created a coupon to see and then when I tried adding it to a product, it wanted to go to "products_Search.php" but the files the uploaded from you was "Products_Search.php" with a capital so that is why it did not find the file, however when I manually went to the "Products_Search.php" and add it, when I went to admin home the horizontal bar did not have any links. I am not sure if I am going crazy.
Also can I make a coupon with quantity based or do I have get around that with figuring out the dollar range?
Jimmy Wu
If you go into Dreamweaver and perform a search on all the pages in the PowerStore directory, you should find 3 places where the products_Search.php should be changed to Products_Search.php. That way you won't have to manually change it and then navigate there. Try making that change and then adding the products directly.
In the coupon system currently, there is no built in way to determine to add the coupon if there is over x number of items. You will have to use the value added to cart.
Jason Kline
Hi Jimmy.
I discovered this issue today as well. PowerStore is a pre-built solution that does not require Dreamweaver or other tools. On pre-built solutions Webassist should provide the updated pages with the fix to this issue. Right?
Jason
Jason Kline
After making the modifications above when I try adding a coupon the complete Admin menu disappears. I cannot get it to come back unless I close the browser and re-open. Please help.
Jimmy Wu
I apologize, when we release updates we try to do some extensive testing, so that's why sometimes issues are known, but aren't in the released versions.
As for the menu disappearing, I wasn't able to reproduce this issue. Does the menu disappear completely or does it show up as text or anything? What browser are you using?
Jason Kline
Hi Jimmy,
The entire menu is gone. I have attached a screenshot. I am using IE8.
Jason
Jason Kline
Hi Jimmy,
Will I get one repsonse per day on this issue?
I don't don't think I mentioned it but this is a critical issue for me.
I want to create a Free Shipping coupon for certain products and services.
I want to schedule sale coupons for products.
Jason
Jimmy Wu
I still haven't been able to reproduce the issue. Can you try using a different browser and see if you get the same issue?
Before you made the modification, if you navigated to the page directly, did the menu disappear as well?
I try to get responses out as quickly as possible, so you may get responses more quickly, but its not guaranteed.
Jason Kline
Hi Jimmy,
I reproduced it in FireFox. The menu is gone. I change the files back to the original and it works manually if I change the "p" to "P" in the address bar.
Do you need Test Engineers to test your pre-built products before your release. Let me know I have six years experience.
Jason
Jason Kline
Hi Jimmy,
Now when I try to remove the coupon from the product. I does not remove. After trying several times to remove the menu disappears.
Jason
