HTML Editor
Can someone at webassist help? The HTML editor code in "guess.php" uses ereg_replace which is deprecated and errors occurs when you are running php 5.3xx. Will webasisst update their source code?
This comes from the FCK Editor files. This will probably not be updated until a new FCK or CK editor is used that does not make use of this function call.
As a work around you can add @ in front of this call to supres the error, or you can try replacing it with preg_replace, this is the newer function that should be used. It takes similar parameters so you should be fine to just update it.
