power gallery /data question
Thread began 6/20/2010 1:43 am by i.edwards384429 | Last modified 6/21/2010 4:05 pm by Eric Mittman | 810 views | 2 replies |
i.edwards384429
Hi
probably not the correct forum but .....
Ok getting somewhere thanks to the team with an ongoing site for models.
I now can upload images link them to the database etc all done using the user registration module.
Using the dataassist extension I can now search by,ethnicity,sex,age etc and on the attached results page display the details.
What I need to do is have a clickable button that takes the viewer to a page where a power gallery will be built dynamically using the user id as the base.
On this form I want to be able to put a simple contact form which will email the viewers contact details to the model (but this comes later)
I assume this is possible?
Any help hints assistance will be helpfull
thanks
Ian
i.edwards384429
forgot file
HJi
forgot to inclujde search file
Doh!!!
results.zip
The first thing you would need to get worked out is the page that dynamically creates the gallery. Do you have a page like this already? This is really the key to this. You would need to have this page successfully creating the gallery for you first. Once you can do that then you can easily add in a button that will take you to this page with the records id, it can just be a link or a form with a submit button. When you insert the new gallery you can just reference your id value that was passed over the URL or posted to the page.
Once the page is crafted and creating a new gallery then you can add in the contact portion to the form.
