How to check for logged in
Thread began 6/19/2010 11:58 pm by johnlanglois | Last modified 6/30/2010 6:04 pm by Eric Mittman | 858 views | 3 replies |
johnlanglois
Is there a way that we can add code to PowerCMS that would recognize whether the client was already logged in? At present, the client logs into the site for other purposes and then has to log in again to use PowerCMS.
What variables would need to be set?
Thanks.
In order to bypass the login for the admin you just need to pass the restriction rules that are applied to the page. The main rule is for 'Administrator' and is setup like this:
session variable:
$_SESSION['AdminLogin']
This session variable must hold the password for the Admin user.
You can check the username or id after you login and if it is the admin username or id then you can store the password in this session variable.
johnlanglois
It worked
Thank you, Eric.
That strategy worked. Is there a way to distinguish between a user level and an admin level doing that?
This is kind of a custom technique to auto login the admin user so the regular access levels would not really apply. You could however have a recordset that selects the admin username and password from the wa_settings table and compare them to the value the user entered, if they are correct then store the password in the session variable. This is essentially what the login for the admin area is doing.
