Using CSS to expand visibility of image
Thread began 6/19/2010 6:00 pm by carm4c386096 | Last modified 6/21/2010 2:10 pm by Eric Mittman | 626 views | 1 replies |
carm4c386096
I'm wanting a header image to expand it's width as the browser window expands from 800 pixels to 1024 or from a 4 X 3 monitor to a 16 x 9 monitor.
So in a smaller browser window, the right side of the image would become cropped, but become visible as the browser window expands.
Is there a way of doing this by placing the image in the container background field and using css to achieve this.
Also have this work in both EI and Firefox/Safari browsers with out to many hacks.
Chris
You should be able to do this by having the image inside of a div that you are controlling the size of. If you set the overflow to hidden and set the size of the div to be a percentage it should give you this effect. Here is an example of how this might look with inline styling in the html:
<div style="width:50%; overflow:hidden;">
<img src="your image file here.png" />
</div>
