What is the condition result for a failed log in
Thread began 6/18/2010 8:13 pm by paulshoe379536 | Last modified 6/29/2010 11:50 am by Jason Byrnes | 1101 views | 7 replies |
paulshoe379536
I want to have a link on my log in page called "forgot your password?" so the user would not be redirected to another page if the log in failed, but stay on the same page. This requires a notification that the attempted log in failed.
I there a condition that is set by a failed log in? If so, I would like to use it to nofify the visitor?
in the authenticate user server behavior on the login page, set the failed redirect to go back to the login page using a URL variable:
login.php?failed=true
you could then add your link to the page with an if statement:
<?php if(isset($_GET['failed']) && $_GET['failed'] == "true") { ?>
<a href="forgotPassword.php">Did you forget your password?</a>
<?php ?>
paulshoe379536
thank you... that was the solution I needed... I learning!
you're welcome.
paulshoe379536
whoops! spoke to soon...
The URL parameter "failed=true" is also getting passed to the page called from the login page (my destination page). How do I clear the URL parameter when the login is successful?
In the authenticate User server behavior on the login page, uncheck the Pass Original Querytstring on redirect option.
paulshoe379536
Thanks, that seemed to have answered my question.
What is "Pass Original Querytstring on redirect", and when would I use it? I looked through the documentation, but didn't have much luck finding an explaination. Can you give me some information or direct me to the document that explains it?
Thanks again...
in the security assist help documentation for the Authenticate User Server Behavior
index.htm
  Pass original querystring: If a query is currently maintained in your session from prior to authentication, checking this box will pass that querystring on to the redirect page.
