Upload pdf file
Is it possible to upload a pdf file and link to it using HTML Editor? I can see how to do images just not docs, pdf etc Thanks.
Here is a link to a thread that should help you out with this:
showthread.php?p=52355&posted=1#post52355
It's enable in the config, but won't accept the file type.
Any clues of what going on?
Did you add it to the images list of file extensions? This is where it should be added to get the same result as the user in the thread. Once it is added you will need to upload the file that you altered before you see the results. What happens when you try to browse for a PDF file to upload?
