New page called from menu...
Thread began 6/17/2010 7:58 am by jed193733 | Last modified 6/17/2010 3:13 pm by Jimmy Wu | 870 views | 3 replies |
jed193733
I need to be able to call a different page that Products_detail in PS3. I'm looking to have a different page layout per category. I've added a page field in the categories database and am now looking to call that variable when the menu option is selected. In the products_results page I'm going to change line 510 to pull the variable.
1. Does this seem like a good way to accomplish this? Am I missing something?
Jimmy Wu
Making modifications like this isn't something that's supported, but I could give you some high level explanations on what you need to get done. You will have to actually implement it yourself.
Are the page layouts going to be significantly different that they can't be modified using a css style sheet? What you could do is to load different style sheets for each of the different products. Then load the different style sheet depending on which product is selected.
I'm not sure which line you're pointing to on the products_Results page. Line 510 is just a closing div tag.
jed193733
Understand the level of support - actually got working i'll post the link when it's live. Thanks for the thought of the CSS file. I'm still a little old school and working with templates, frame but it was a good inspirational suggestion.
Jimmy Wu
It's good to hear that you're able to get the customizations done. It will definitely be nice to see how your store ends up looking.
jed193733
This post has been deleted.
