DB Connection Loop
I'm trying to access the menu on my powerstore 3 site and CSS MW says the connection is no found and just loops.... I had to use task mgr to kill the operation. What am I missing?
I wouldn't recommend editing the menu on PowerStore using Menu Writer. The reason being is that after the menu was applied using Menu Writer, there were additional modifications and code that was added to get the functionality for PowerStore working. If you edit using Menu Writer, these hand coded parts will be overwritten and removed. What are you trying to edit on the Menu? I may be able to point you to how to make the edit without using Menu Writer.
Check out this post over in the PS forum. New page called from menu...
Which thread is it that you wanted me to look at?
