Site Sculptor menu problem
menu does not appear on the site. What can I do about this issue
Please post a link where I can see the problem to examine the cause.
iletisim.php I added the missing files myself
It appears to be working now. I'm not sure I understand, where the files missing (not uploaded) from the server?
No. in fact, does not work. Please log in to contact page
iletisim.php NOT WORKING
the issue is onlu occuring in IE, not in fire fox or safari.
the problem is that there are comments in the code before the doctype tag:
<!-- saved from url=(0014)about:internet --><!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
this is causing IE to render the page in quirks mode using the IE 5.5 rendering engine.
remove those comments that are around the doctype tag:
