Adding a Page to Site Sculptor Site
Thread began 6/16/2010 12:34 pm by larry268887 | Last modified 6/16/2010 12:45 pm by Neil Beadle | 560 views | 1 replies |
larry268887
I have a file named information that is set as a content management template. When I click on the + button a window appears saying add a new page based upon template and asks content name which I filled in as test. I can then edit the content but when I go to view the page the following address appears information.php?Information=1. When I go to the information folder there is no test.php but there is information in the database for test.
What I'm expecting is CMS to create a page call test.php in the information folder based upon the information template.
Am I wrong in this assumption?
To achieve what I want I have to create a file test.php in the information folder. Then I have to modify this file so that all the cms content areas refer to test. Then I have to go into the database and modify the test entries. Then I modify the menu using menu writer. Then I have to modify the two menu.php files. Once this is all none every thing works as expected.
Is there a simpler way to achieve this?
Neil Beadle
Hey Larry,
Site Sculptor's CMS cannot create actual files for you. Instead the templating concept allows you to create dynamic pages that are the same file as the template, but the content changes dynamically.
This has been discussed quite a bit in other posts. For more information, i suggest you start here:
showthread.php?t=13584
-Neil
